Okay,
I kinda sorta understand LEDs I think. I have played with them a little but mostly single LED’s with pre-wired resistors. I did run a small string of them in series with a single resisto but don’t remember enough about what I did to make it work.
So here is what I want to do. I have discovered “pico” LEDs Now for modeling these little suckers are the cat’s meow. At 1mm they are tiny and the original place I bought them from had them pre-wired with a resistor and they work over a nice range of voltages. But I want to run a series of them. I won’t bore you with the details of what I am building except to say I want them in series and want to use only a single resistor. Think Christmas lights. I know that when playing with LEDS voltage is a concern but more so is miliamps. As long as the voltage is within the usable range of the LED, say 12v, then I have to know the mA output of my power supply and add up the number of LEDs and their mA rating and then provide a resistor to protect from the extra amperage, right?
If the LED runs on 12v and is rated at 20 mA and I have a 12v supply that produces 100mA I can run 5 LEDs in series with no resistor. Any more and I run the risk of not powering them up and any less and I run the risk of burning them up without the use of a resistor. Resistor sizing I know is based on the total mA supplied and the total mA draw with all LEDs combined, right? So if I have this correct, then I need to know how many LEDs I want to run, how many mA they draw and either provide enough power to run them or add a resistor to protect them, correct?
And to further complicate things, I want to run a single source, likely 24v, on a single set of wires around my entire indoor layout with feeders to each of the locations. I would want this sized so that it will run a whole host of buildings, cars, and other details. So can I knock down each feeder to the correct voltage and then add a resistor to give me the needed V/mA at that particular location? Greg and I talked about doing this when I was doing 1:24 and running the wire on poles and having “transformers” at each location. This is out now that I have gone to On30, the wires would be way to big to be anywhere near adequate to work reasonably. So all of this will be under the bench work or in the building itself. So is it best to run a “big” power supply and knock down each feeder and make each feeder individually designed to provide the output I need for that particular area then running all the LEDs in series?
