Am I understanding that the driver replaces the resistor? And if so can a single driver run several LEDs in series?
We need to get back to the original plan. While LED theory is nice, I am a dunderhead when it comes to this stuff. I don’t know why as I consider myself to be reasonably intelligent. I know at some point while messing with them it will sink in. But I do have some sort of block when it comes to this so dumb it down for me.
I want to run a string of say 15 or so pico or nano LEDs around a tree to make it look like a string of Christmas lights. Having some dohicky like a resistor attached to Every LED will mean a heck of a lot of “stuff” that won’t look very pretty in my tree. Or a pile of wire going somewhere else and attached to all the dohickies. I don’t see that as at all practical. Now if a single resistor or driver will run say five (or even all 15) with a given power source then I could see them in series or even in parallel and having the dohickies elsewhere. Either way, in series or in parallel, running 3 strings of 5 or even 1 string of 15 would look much prettier.
Now with all that everyone has said, It seems that if a given LED runs at 2.4v and 20mA and I have 12v/100mA source then theoretically I could run a string of 5 LEDs with no resistor in a series. Now I understand that adding a small resistor would add protection but lets leave that out for a second. Each LED being a diode and not a light bulb I understand that I start with 12v and in series knock down the voltage by a factor of 2.4 at each with each LED, so 12-2.4=9.6-2.4=7.2-2.4=4.8-2.4=2.4-2.4=0. And since I have 100mA and each needs 20mA then 20mA X 5LEDs=100mA of required current. If I have this correct then I further assume that the first LED in the series is not really receiving 12v which would burn it out but that the collective of [email protected] “evens out” the voltage to be 2.4 across the series? Do I have that at least sorta right?
Now lets work on parallel. I will use the same LED at 2.4v 20mA. No matter what a parallel circuit maintains the given voltage, right?. So regardless of 1 LED or 100 LEDs at the end of the run I still have 12v. Because the LEDs are all wired singly to the positive wire they won’t rob voltage from the next one because they are not really in line. !2v is carried across the entire positive feed clear to the final LED, right? As far as voltage is concerned they do not “see” the other LEDs in the string. Each one gets 12v. But wouldn’t current still be a factor and 5- 20mA LEDs would still require 100mA source to provide enough current. If I understand this then each LED would need a resistor so that it only sees 2.4v and only 20mA of current instead of the full 12v/100mA being provided at the feed?
Yes, no, sorta? If I have this anywhere near right then It would almost seem to make sense to me if I want say 15 LEDs running off a single 12v source then a 300mA source could be used to make a hybrid system of three (3) 5 - 2.4v/20mA Leds strings in series with each if those strings run in parallel would make sense. Each string would use up the 12v and 100mA and since each string is in parallel to the other each string will see 12v and each string will take 100mA of the available 300mA, right?
