First off, I am relatively new to the forum and new to G Scale. This forum is a wealth of information. I have read many posts on the Ladder Roadbed method but still have a couple of questions. Just trying to learn as much as I can before I go off and make my own mistakes!
Here are the particulars of my layout. I live in Texas so temps will range from 110 to 20 F (thankfully, not often!). It needs to be as dog proof as possible (energetic 80 lb Giant Schnauzers). The layout does not lend itself to be raised. I will be using battery power. I will be using 332 Brass in 6 foot flex as well as 5 foot straights that all will be bent with a dual rail bender. I am going to try to avoid sectional track as much as possible.
Questions:
- What is the best way to attach the track to the ladder ‘rungs’? How snug should it be attached?
- How often should it be attached?
- Is it better to attach in curves or straight areas?
- I have rail clamps and Aristo/USAT rail joiners with screws. Should these be tight or loose to allow for expansion/contraction?
- Any other suggestions that will help?
Thanks for any and all input!
Tom
Aggieland & Big Sky Railroad
