Hi folks,
I am planning to build some raised track on aluminum trestles similar to the one pictured below.
The trestle pictured has aluminum rectangular tubing for the roadbed, which works very well. I have also used 2x6 PT laid down flat on top of the trestles without much warping…but I think I was lucky.
My new trestle is going to be more of a long raised layout vs the short trestle above. Likely a couple hundred feet… My question is: Do I build the bridges entirely of aluminum or do I consider using a ladder roadbed technique for the track deck? And if so, should I use PT, cedar, or composite?
Also note, I plan to add walkways to help protect the trains in the event of an undetected acorn or such!
