Got 2 “1x2” pvc boards and some 1 1/2 inch pipe yesterday for Sully’s mountain area. The 12ft boards said $14 each, but rang up at $22 ea, so I’ll do some investigating before I let him buy any more. Track seems to fit nicely across the 3/4 inch boards screwed to the sides of the 1 1/2 inch pipe, and it seems to be quite stable. We used little short pieces of pipe for spacers between the supports.
We only put supports every 3ft. Perhaps too far apart?
The track is about 2 1/2 ft off the ground here and slopes about 1% down to ground level. Actually, the ground comes up quite a ways too. The plan is to build more mountains, but I wanted to be sure when I was building mountain of the height of the track. We’ll also turn some of this into trestle or bridge by adding decorative structure.
The only heavy object I can see falling on it is Sully himself.
