I was disappointed that the video does not show how the uncouple operation is done via the remote. Of course I’d also like to see how the system is actually set up. I would THINK that you would use your current car numbers - (and hope you don’t have ANY duplicate numbers in your fleet.) This is typically not a problem in operations, because you’ve already eliminated duplicate numbers in the same road name to avoid confusion. I would also think that you would need to install two servos per car, since you would need to uncouple the correct end. So, using their remote
(http://www.remoteuncoupling.com/images/remote.jpg)
Let’s uncouple a car: Let’s see …key in first car number …hit some key - let’s use the # key on the keypad… (I’m not sure what they actually use) Key in car end…hit # key. Now, key in second car number…hit # key. Key in car end…hit # key. Now hit some other key (maybe the key on the left side of the remote?) to initiate the uncouple. Yay, I’ve uncoupled two cars.
Or, perhaps more likely: Oops…something is not right…do I start over? :o I think I’ll stick to manual uncoupling.
No tools needed here…I use the Accucraft coupler.
