I would like to give credit to this idea to Terry Burr who’s idea I adapted in a slightly different way.
The Bachmann K27 has a fantastic equalized suspension that allows it to navigate fairly bad track. The downside is that it can sit back on its rear with the result that the pilot and front driver can lift from the track.
Weight was added to the front of the second production which helped a lot but did not solve the problem.
Terry’s fix was to place a spring on top of the gear box to try to force more pressure on the front driver and pilot.
I have implemented a slightly different solution that has the same effect.
I placed a very short piece (between 1/16 and 1/8 inch) of 1/”16 brass rod inside the two axle springs of the 4th driver. This slightly lifts the rear end and makes it much more difficult to lift the front end.
It takes around 20-30 minutes to take out the 4th driver and perform this modification but is very simple as the 4th driver can be removed without removing any of the other drivers.
I tested this on one of our Ks and the result was very positive. I would be interested in the result of others who try the same approach.
Stan Ames
