How to turn R1 track into straight track - Quick and easy
Hi all
Well, I’ve bought my two year old grandsons two Thomas sets (Thomas and Percy). I thought about extending their temporary layout using some additional pieces of Bachmann tinplate track but was stunned by its cost – 6 dollar for 1’ piece of track, 32 dollar per switch; and it can’t even be use outside.
So I looked around for better alternatives and found, a little too late, Aristo aluminum track. Trainworld was selling boxes of 12 R1 pieces of track (one full 4’ circle) for 19.99, or 1.67 dollar per 1’ piece of track. Unfortunately, no straight pieces were available. I nevertheless ordered three boxes of R1 track, plus 2 large radius switches and 4 small radius switches (this ones in brass, since they were not available in aluminum. Aluminum is not a problem for me because I’m a 100% battery man).
I then snooped around for compatible aluminum track in the internet. A big hope was Polk’s GeneratioNext, but unfortunately they do not sell internationally, and none of the shops that sell their line (RLD Hobbies) have aluminum track available.
Well, having received my order from Trainworld some time ago, I decided to investigate it. Toying around with a CAD program, I found that the inside rail of an R1 piece of track has a length very similar to the length of the standard straight (302 vs. 300 mm). So, it will be possible to easily make a standard length of straight track by using two inside rails from two R1 pieces of track – keeping this length is important to easily make parallel tracks using small radius switches – remember this will be a portable layout.
The outside rail is longer than the inside one. The distance between rails centerlines being about 47 mm, the outside rail will be longer by pi x 47 x 2 / 12 = 24.6 mm. This is more or less the standard distance between sleepers (11 sleepers per 300 mm = 27 mm distance). So, it will be possible to use two outside rails from two R1 pieces of track to make a longer piece of straight track with 12 sleepers instead of the standard 11.
The experiments I’ve made have shown that conversion is indeed possible and, more important, it’s easy and quick. I can transform a 12 piece box in less than two hours. I’ve ordered a further four R1 boxes from Trainworld.
In the next photos I show how I make the transformation.
Photo 1 – Necessary equipment – Screwdrivers to remove screws from the railjoiners and to loosen the rails from the sleeper base, plier to cut the sleeper base web, rail bender to straighten the rails. I’ve used a Sunset Valley code 250 rail bender that I’ve used on my code 250 main layout. I don’t know why but it fits perfectly the Aristo code 332 rail.
Photo 2 – The two pieces of track disassembled. Make sure you store the screw safely: they are very small.
Photo 3 – Using the wire cutter from the plier, cut all the elements of the outside web of both sleeper bases. Each element must be cut twice, in order to remove about 2 mm of web. This ensures consistent sleeper spacing.
Photo 4 – Final result on both sleeper bases.
Photo 5 – Straightening the rails using the rail bender.
Photo 6 – Perfect fit of the 332 rail on the 250 bender.
Photo 7 – The two straight pieces of straight track, one standard length and the other a little longer. Note the spare sleeper that will be used on the longer track.
Photo 8 – The final result, and comparison with a short radius turnout. Sleeper spacing is similar in all cases.
Hope this can be useful to someone who may want to get rid of his R1 track.
Jose Morais
Headmaster of the Lapa Furada RR
