Todd,
The two passes on the planer is to set the angle. I have the depth on my joiner set very shallow, somwheres about .020 per pass, hence the two passes to set the angle. Once the angle is set on the joiner, then go to the table saw to make the straight back cut, and part the clapboard from the base stock.
The comments about two table saws was that I know some of the fellows here have both a full size table saw AND a hobby saw like a Proxxon. Assuming I had two saws in stead of the joiner, I would use one saw to set the angle, and the second saw to make the straight cut. Just another option.
To keep progress moving forward, most of my projects will have several different lengths of material required. I would cut several lengths of 1 by stock to length 1/2 to 1 inch longer than the finished length of the milled finished product. That would allow me to go to the joiner and set the angle on multiple pieces, then to the saw and rip them to width, back to the joiner to set the angle and back to the saw, etc, etc.
Randy,
My stacked dado blade leaves a small groove at the bottom outside edge of the blade that when used for it’s intended purpose is never seen. But doing siding it is quite noticeable. I don’t know if the blades are ground wrong or what. What you have shown gives me an idea though. When I purchased my first Sears table saw, it came with a shaper blade and one set of ‘square’ paddle type blades. It might take some fiddling with an insert to make it work, but that might work for clapboards. If I can remember where I put it I will get a pic posted.
Do you thin the thickness of your boards before milling the siding? It appears that the sample shown is only about 1/2" thick.
My process was predicated by Todd’s statement " How can I setup my saw to cut individual planks for clapboard? Is it possible?"
Bob C.
