Steve Featherkile said:
Do they name each track in a yard? I know, or at least suspect, that each siding is named, each switch is probably named, as well. Witness East and West Berne for the switches on the passing siding just east of the Cascade Tunnel. How about the switches in a wye?
To me, it would make sense to name, or at least number, everything that has any significance on the railroad, to avoid the possibility of confusion.
So, my question is, “Just how anal do the big guys get?”
Steve,
Very anal! Wonder where I get my anal modeling from?
Multifold question(s). I’ll attempt my best to explain. Every single track (yard, siding, mainline) has an official track number. This number is used to identify to MOW (and Engineering) the location, and type of track. Tracks also have common names such as “Berne Siding” or Track 10 at Stacy St. Yard. But the official number of track 10 at Stacy would be something like 12010 (120 signifying the name of the yard, 10 for the individual track).
So yes both tails of the wye would have numbers. Turnouts are have even more specific numbers. Using my example the turnout at Stacy 10 would be 12010-9. The last number would signify the turnout type, frog etc. I’m sure a MOW guy could tell you even more.
But the common names for things are pretty simple.
Stations/Sidings such as Berne, Cascade, Scenic, Merritt all take their names from physical stations that once existed. These are listed in the official time tables as Stations, showing siding length, location, and any extra important thing like a telephone,etc.
When you get to yard tracks most yard tracks are known by the track number. At Stacy were I worked a lot we had the following tracks; main yard 1-19, SIG 1-4, SIG Running, Industrial Lead, Sugar, Steam, Whatcom 1-4, North SIG 5-8, West Seattle Wye, UP Interchange, PC Running, Colorado, PC3, etc.
Some of the industries would have track names such as the Mud 1-3, Ramp, Storage, Running, Ford Lead, etc. I’m sure I could come up with a whole bunch more. But the point is each track has an official designation, plus a common name. The common name usually has some sort of connection to the history of the track or the industry that is served by the track. The SIG tracks are Seattle International Gateway 1-4 where containers are loaded on to COFC’s. The PC tracks are named after the Pacific Coast RR that used to own them. The Mud tracks are named because they are muddy.
Every control point on the mainline has a name. This is two fold; one to be able to define authority for track movements, and to identify where you are at.
If the dispatcher is giving a track inspector track and time from ESS BERNE, control point NO to WSS Scenic, control point YES as an engineer I know exactly what his limits are.
Or a TWC territory with a track warrent.
Proceed from CTC Siding Ellensburg to CTC WEST Kanaskat, main track.
Or the YM tells a crew to grab the PC2, run through the Colorado, cross over at the Spokane St. crossover, fill up SIG 1, double to SIG 3, cut the crossing, light power down the SIG R, power to the Cab.
Simple huh?
