For my indoor layout I am doing a more or less backwoods lumber and mining railroad. As such I want to have the look of hewn log ties as opposed to milled ties. My MIK project is the first thing being made for the indoor and it is the engine house. I needed some ties coming out the door so it was time to figure out how to do it. Awhile back someone on here gave me the idea of cutting limbs to length then sanding one side flat and then gluing them to a board and then sanding the opposite side flat to a uniform thickness. So that’s what I did. I cut twigs ranging from 3/8 to 1/2 inch in diameter 3.75 inches long. Then sanded one side flat and since the limb is green dried them in the kiln (the oven) for about 15 hours at 175. This seemed to dry them out pretty well. Then they were glued and pinned to a piece of 3/4 MDF at a spacing of 11 or 12 to the foot and then sanded on my belt sander to a uniform 1/4 inch thick. I only did two small sections to fill in the left over rail pieces sticking out of the engine house. The track is not spiked down yet. Oh and I used some very dark stain to kill the bright white of the wood. I like the look a lot. Really did capture what I was after. And since the indoor will be only like 30 or 40 feet of track it won’t be to awful tedious to do.
Edited because I forgot poctures
