David Maynard said:
I wasn’t talking so much about air pressure build up, I was talking about heat build up. We have all gotten into a car on a hot day when the windows were left rolled all the way up, and we felt how much hotter it was inside the car then it was outside. You are building buildings with plastics. How much heat can they stand for how long before the plastic starts to get brittle? If letting cooler air in at the bottom, and hotter air out the top, extends the life of the building a few years, then isn’t it worth it?
My thoughts,
Heated air “pressure build up” in model structures is not an issue at all, in my opinion. But, as David said above, hot air relief is an issue when it comes to preserving the integrity of your buildings material and your glues/solvents over time. Take a look at the structures we live in, the attic spaces are well vented high and low for air flow to unload built up heat. This venting helps preserve the building materials as well as lowering your cooling costs.
There is a second reason that the attic of your house is ventilated as is the crawl space under your home and that is moisture/condensation issues caused by temperature changes and the air releasing it’s moisture.
I haven’t seen this mentioned here in reference to model structures but, here again in my opinion, it is the main reason to vent our model structures. Maybe not quite as important in a building formed of Acrylic or such but in any wood application non venting is built in self destruct. All of my structures receive venting no matter the size, even the flats only 2 inches deep are vented.
I use small ( 1 inch round) aluminum louvers, you can get these at Lowe’s etc painted or unpainted for about 10 bucks a dozen. In places that don’t show I just glue on a piece of Vinyl window screen. These methods keep the bugs out and let the air flow.
Really enjoying your design stage Cliff.
Rick
