There will be 4 roof structures, all lift-off in nature.
Though the larger roofs will be reasonably heavy, there may be wind issues, especially for the smaller ones. If that becomes the case, I plan on drilling holes through end walls and into the rafters behind them, enlarging the outer (wall) hole, and inserting a fastener such as a sheet metal screw. Not elegant though, and the rafter might crack. Maybe just a SS nail poked through would be better. I’m open to suggestions. For the time being though, I’d like to see how well the roofs do over a season, just with gravity.
The legs pointing downward are to allow the assembly to be set on a table for shingling, detailing, etc., or to just be set aside on the layout without damaging the shingles or trim.
BTW, the internal “walls” and “floors” in the core structures are only bracing, and do not correspond with real life features. My objective is to make these structures strong but lightweight. As a point of reference, the main (green) core weighs 19 lbs (without sheathing & detailing), and its roof weighs 8.5 lbs (without shingles & detailing).
As for vents, I’ll probably end up putting holes at peaks, through wall and rafter behind, and gluing on a louver like I did on the test building. Still pondering the inlet, David.
Thanks for the input & ideas guys, and thanks all for viewing.
Cliff
