I don’'t run my Shay in the garden often. Today I reminded myself why.
While it does fine on my grades running light, if I try and pull one car and a caboose up the hill it will slip all the way up. It’s worse after a few runs and the rails get oily - can’t even get the cars up the hill at all.
It also doesn’t like my Aristo No. 6 switches and derails quite often on a switch. When it does it usually separates the drive-line linkage which is a royal pain to reconnect on the ground; especially when the loco is hot.
I ran for several hours today; taking fuel, oil and water breaks. When I was done I was just tired and didn’t feel like I had any fun. I suppose I could build an elevated live steam track as I have the room, but that type of operating doesn’t excite me at all.
One problem may be that I run stainless steel rail which is extremely smooth. I could try cleaning the tires on the Shay to remove any oil build up and/or run a cloth track cleaner on the grade between runs. I could also finish my log bunks to supply a lighter train to pull.
Can the Shay trucks be gauged at all or are they fixed? My other locos and cars generally do fine on my switches.
Maybe I’m just a wanna-be live steam guy and should stick to my sparkies.
