Nick Jr said:
Gerald, what volume of liquid does it hold and how often do you have to pull the plug.
Thank You nick jr
Hi Nick!
Sorry for my later answer, have not so much time, much to do and think because comming weekend Regner in Germany celebrates his 35 Year Factory Jubilee, me and other guys from schienendampf.com will drive their locos at this jubliee.
The oiltrap is a simple Bass Tube, 50 mm long, 18 mm diameter, it think the brass is 1 mm thick. I drain it when the boiler has enough temperature for running the machine before starting. And when i make a stop to add water through a godall valve.
Because this are the two times, i think, when you need a oiltrap.
Before running the steam condenses in the cold cylinder to water, and meanwhile you make an Tank Stop, the Cylinders is getting colder, so the first steam also condenses.
Like i wrote before, the better place for the oiltrap would be a place near to the gasburner so the water in the trap vaporizes, my place (under the longboiler) is not the ideal place, has not so much heat, so i have to drain it using the drain valve.
But never mind, the Shay runs very good, i have much fun with the machine.
Last weekend we had a little steam fair, just half hour from my hometown.
Here’s a short video from the steam fair, my shay is running one round on the layout from Franz (also a member from schienendampf.com) The noise comes from a summerland-chuffer wich is mounted in the smokestack of the shay).
http://www.youtube.com/watch?v=1ScYlBQ-t44
Greetings from Austria, Gerald
PS:
Jon wrote:
“I looked at the forum post you linked, Your mod is very nice but far beyond my skills.”
Cheer up jon, maybe you know a person, model-railroader or neighbour or some other who can help you. I hope for you.
