Fred Mills, BSc, BS, SD said:
It is common knowledge, in deep frost areas, that any posts put into the ground, even when concrete is used to support the post in the hole; will move with the frost, unless the post is in deep enough to bottom below the maximum frost depth.
I have a large fence post with a gate on it. The other end of the gate is latched to a fixture on the house.
During the full year, the post moves in the soil anywhere from an inch, or three, up and down. Even the moisture content of the soil causes this fluctuation…along with the frost. It sure isn’t the house moving, as its foundation is on bed rock…
I can’t understand the use of those “Pipes” to support the ladder roadbed. Why not just support it with backfill, and or anything (Rocks, old bricks, dead body parts, etc) you want to get rid of. This would save the cost of the pipe/posts, and avoid putting them into the ground, to be moved by the frost.
But…as I suggest…what do I know…I’ve only been operating a outdoor railroad on PT roadbed for 20 or more years, and am still learning…!!
Fred, the front porch on my house moves just like your fence post. I have also noticed that my cement driveway will move up or down a little from time, as it slowly creeps away from the house. I too float my track in ballast. But I didn’t put any supporting structure under my track. Some springs I wish I had, but most times it works out ok.
As for supporting anything on dead body parts, that only works for so long. The body parts soon decompose and no longer add support to whatever they were supposed to support.
