Definitely a work in progress but the main parts are all there. I need to fuss over the points themselves a little more, especially the one for the diverging route. I looked at a few dozen prototypes but I can’t seem to get that same look to where the points lay over the rails but for now the cars seem to roll through just fine.
I worked on the frog for quite a while trying to get the bend in the rail as sharp as possible. I discovered that a small cut to the base of the rail allowed a sharper bend as opposed to the kind of kinked curve I was getting before. Also I realized because of the amount of “slop” between rail width and wheel width, there is no way to get as tight a frog as the prototype. I am getting just a little bump through the frog but I think I am being very fussy about it.
I do know that large scale is much more forgiving than N scale, as far as hand laid turnouts go.
And the guard rails are not tacked down yet, either. I think I will use my thin sheet steel to concoct some turnout tie plates and it might be fun to do some other detailing down the road.
Next step is a switch stand and a proper signal. Something “old timey” but lit up, not just a target. Again, I’m not so concerned about mixing up eras a bit, just don’t want it to be too obviously modern.
What do you guys think?
Any input or suggestions to make the next one better?
BTW, this was all done completely free hand but it turned out to be a #6 right on the nose.
