Patrick McGrath said:
Definitely a work in progress but the main parts are all there. I need to fuss over the points themselves a little more, especially the one for the diverging route. I looked at a few dozen prototypes but I can’t seem to get that same look to where the points lay over the rails but for now the cars seem to roll through just fine.
What do you guys think?
Any input or suggestions to make the next one better?
Patrick
Looks great.
I have been building stainless Steel code 332 turnouts for our layout when a commercial one does not fit well.
Over the years I learned that outdoors it is best if I pre-drill holes for the spikes and use CA to hold them in place. Before I did this the spikes tended to work themselves out of the ties over time. I also now solder a few tie plates to the rails and screw them into the ties. Does not look as good when you look closely but since doing this everything has stayed in gauge with no maintenance.
A thought on the standards. I grew up believing Back To Back was the key wheel standard and keeping the guardrails both at the frog and the stock rails as narrow as possible within the standard was the key to success.
Some years back I attended a clinic who purpose was to convince the attendees that Check Gauge was the key dimension. At the time I tended to think he was a little off the mark but over time I have learned that in Large Scale, Flange Width and Check Gauge and not back to back are the key.
I now build turnouts that have the guard rail next to the stock rail in standard only across from the end of the point and wider at both entry and exit.
The guard rails that are part of the frog have a wider flangeway. The advantage is that all commercial wheels glide smoothly through the turnout.
Hope this helps
Stan
