Some of you may have seen the thread where I’m searching for a portable track for the EBT fall reunion. These tracks are lots of fun but always seem a bit bland for me. My hope is to model a scene of Saltillo on the inside straight section to spice things up a bit. To that end I built the first of 3 structures. Saltillo’s Tanks House. The construction is a base of stout corrugated card board. This is topped with some 1/16" thick solid fiber cut outs to form the batten boards and window framing. I did all this on my cnc table at work so it was fun to experiment with a rapid build method. You can see in the second picture that I cut all the strips inside a frame, then dipped it in glue and sat it in place. Once the glue set I trimmed of the frame.
Next came the roof. This is where progress slowed considerably. While my table cut great shingle strips, they still needed to be glued down. Lets not even discuss those lousy ridge caps and having to glue them down one by one. Ugg. But the results were worth it. Last I followed up with windows, a door and rafters in all the eaves.
I just need to use a bit of filler putty here and there, then give it a good dousing of EBT red. Oh, lets not for get a spout…
