I think I may be over thinking this…
Usually my roofs are 45 degrees and that means I can butt one sub-roof against the other. In this build, the roof is not quite 30 degrees.
Keep in mind, my tiny table saw is not set up for tilt arboring, and I still haven’t sourced a pin nailer any where close to a justifiable price to what you guys have. I do have a disc sander.
For this build I was planning to pre-laminate my sub roof to be as rectangular as possible using my square to start the gluing process. Then join each half together.
However this was my best ridge- line result, but I thought I could come back with a flush cutting saw and nibble away at the ridge.
On the other hand, if I sand each board to thirty degrees I can get this result, but I’ll probably have to lay each sub roof board on the rafter separately, as the center-line is not quite centre. I also think I’ll need to do both sides at the same time. I suspect there will also be a little wandering in my sanding and gluing preventing an easy line up of a mitred edge which might in turn give me a sloppy drip line too.
Am I over thinking this? Can anyone remember what they used to do before they tooled up?
Thoughts?
