I’m redesigning a section of the RR and plan to put in a tunnel. In other sections of the layout I have used cement block and 12x12 flue liner. I really like the flue liner because it can be installed and ready to go very easily the trouble is I can’t seem to find it anymore.
The alternative to flue liner is to make the tunnel from concrete 4x8x16 blocks and then buy large patio blocks for the roof and extra concrete for the floor of the tunnel. The blocks are $1.25 per and the large flat patio ones are at least $5 per so a long tunnel can add up in cost.
I had a brainstorm the other day. What if I placed one layer of the 4x8x16 blocks then dropped a sona tube in between the blocks then cemented over the top of the tube forming something resembling a Quansa hut. The track could then be affixed to a PT 2x4 and fed through the tunnel. a 5’ length of tube is $9.
Eventually the cardboard would rot out but that would be OK since the track isn’t sitting on it.
3 pieces of flue liner 12x12x2 is $75 if I can find it but it is quick with very little mess.
blocks and cement is approx. $50 and more messy work.
block, tube and cement approx. $40 and less messy work.
Has anyone done this?
