Thought I would provide a bit more detail on building rock tunnels. The concept is to build a tunnel that looks like it was blasted out of solid rock.
First photo shows the track edging in and the side walls of about 8" also complete.
Next stakes are put in to set the proper height and the tunnel is filled in with dirt and shaped the way you want it to look.
Rocks are now placed on top of the dirt and end portals are put into each end.
When you are happy with the looks dry cement is brushed on to the top to fill the cracks and then the entire top is covered in cement.
Once the cement is dry its time to dig out the dirt from each end. The length of the tunnel using this method is limited to how far you can dig in from each direction.
When dug out and the track is installed it looks good.
It is really not very difficult and is especially effective for the shorter tunnels that visitors can see through.
Additional photos and higher resolution are posted on my flickr site.
https://www.flickr.com/photos/23959355@N05/sets/72157654621327496
Stan
