OK so for the MIK build I need to build a roof for my water tank. I want it to be octagonal. I am making the panels out of 1/4 plywood. I know that to make a flat octagon the peak angle would be 45 degrees and the sides would be cut 90 degrees from horizontal. But as I lift the peak to form a cone (OK I know that not the right term but I don’t know what it would be called) does the peak angle stay 45 like I think it would and what happens to the sides so that the panels will glue up flush to one another? This would depend on how tall I make it right? Is there a formula to figure it out so that I am not cutting by trial and error?
If this isn’t as easy as applying a formula could I con someone into drafting this for me in a CAD program or Sketch up or something? I think once I know the angles I am smart enough to set my compound miter to cut them right.
