I was redoing the pavement in my town yesterday and took a hard look at some of my older buildings. The gas station was my first scratch-built structure - I made it in 2002. Originally it was 1:24.
After a year or so, I swapped out the vehicles and people to make it look 1:20.
It looked like it could use a repaint and I wanted to swap out the concrete base for one made of PVC, as the concrete was deteriorating and getting ugly.
However, when I took a closer look, I found it to be in REALLY bad shape. I had used thin plywood when I made this, hoping that sealing it good would prevent any problems. That’s not the case.
All of the wood has rotted, and it’s just being held together by the Precision Products sheets. Oh well. The next one will be built with the foamed PVC board. One of my other buildings that looked like it could use some work was the Blue Moon Saloon. This was a kit, made out of concrete, so I was sure it would last! I made it in 2003, and it looked pretty neat to start with.
But, a few years ago, I had to bring it in as a lot of it had just chipped away. At that time, I replaced the concrete base with a PVC base.
I repaired the walls with Magic Sculpt and thought that would take care of it. However, it continues to chip away.
Not only that, but the joints are coming apart, and there’s a large crack in the other side. I really don’t want my buildings to look like they’ve been in a war zone and I’m afraid that this one is also beyond repair. So, some bad material to use for both of those buildings. Now I have to re-make them.
I’ll probably rebuild the gas station to look about the same, but it will be converted to use a 1:20 scale door - the other door was 1:24. Not sure how I’ll do the saloon; it’s really too small for 1:20 - it scales out at 12’ x 14’ - I’d like a bit larger building. I’ll be searching the internet for some prototypes.
I’ll keep the original windows and gas pumps, but they have to be painted with a good exterior paint.
