I have installed Zimo sound decoders in over 10 of the different LGB davenports (2063, 2062, 21630).
I do modify the front grill (drill out screen but leave posts) and install a 2 inch speaker behind it and use a matching Xmas ribbon between the grill and speaker…
The zimo decoders I use will control a smoke unit (I drill out the stack and install an 18 volt unit).
I add standard Kadee couplers and control them with staqndard servos and program in a waltz (Engine will back up, uncouple and then pull forward on its own from pressing one uncoupling key.)
Sound project from Zimo will go through a motor start up and have a rough start up idle that smooths out. Changing direction will give a mechanical clunk for the reversing mechanism.
The 2063 does have a 3 wire motor block. it is the 20635 that has a 4 wire block. I find it very east to convert the 3 wire blocks to 4 wire as I have done this more times than I can count.
P.S. Bob, I have all the parts on hand to do this right here in Massachusetts and can show you several of my units I have working.
