I’ve had time-off work since Friday before Christmas. I had plans to finish up a few outdoor projects this past week, but the weather has kind of put a damper on that. Highs under 20° and lows close to 0°. I did manage to spend about an hour outside Friday taking breaks every 10 minutes or so to warm my hands, but I didn’t get my railroad task done: Bringing in Wall Station and Platform for the winter.
I tried again today even though the wind chill was pretty raw at 4° with thermometer temps about 14°. Being bedded in stone dust this sub-freezing weather had pretty much permanently attached the structures to the ground. Careful use of a propane torch melted enough ice to break them free. The real challenge was getting the buried wire out of the frozen ground without melting it. I only started a few small fires in the process. Wall Station and platform are now safely inside defrosting. I will clean them up a bit then place them on my indoor layout for winter.
I came in over an hour ago and my fingers are still cold!
