A couple of updates… We have tucked the reefer 39 in for the winter in Durango. Tarpped up to protect from the snow and rain…
The Stock cars are all but done, needing only the final little lettering on the sides. They have both been moved to Silverton, and will spent the winter there, and probably the rest of their lives being tenderly cared for, and never again to be pooped in.
The Flat is wintering over in Arboles at San Juan Timberwrites. We are awaiting some funding from grants to proceed to restore her.
The Flanger is snowed in, in Silverton for the winter, and work will resume after the spring thaw.
D&RGW 315 is safely tucked away in the Silverton Northern engine house for the winter.
That leaves the D&RGW 04432 Water Service bunk car, as current projects.
Way back at the start of the summer, we started to replace the roof, and the first thing that I did was remove the roof walk braces. These had been replaced by the crew at The Georgetown Loop RR when they put a modern replacement on the roof.
Well it has come around full circle. I have been tasked to cut and make the replacements.
I have been entrusted with 24 - 3 1/4" x 3 1/4" x 24" long Fir blanks. These were cut from “Old Timbers” by San Juan Timberwrites. On top of the stack (Right side) is one of the braces that was installed by GTL when rebuilt by them, and removed when we started the re-roofing. And on the Left side is a brace that we found inside the car when we cleaned it out. We believe that it may be an original replacement on the car. It has no bolt attachment holes, only nail holes (8), and 6 screw holes on the top where the roof walk boards were attached. This car has wood roof beams, and other work cars that went thru rebuilds (C&Ts) and D&S all have metal roof beams and the braces were bolted thru the center of the car top thru the metal beam. 04432 shows no sign that that was the way the roof walk was attached. This brace also shows the scars of being cut with a hand saw.
Note: when this car was originally built, it had 18" wide roof walks, it wasn’t till the turn of the century that it had to be “up dated” to have 24" wide roof-walks. So we know that it has had at least 3 prior sets, before the set that I will make.
This is the brace that the Georgetown Loop made for their replacement roof. Note the recessed bolt hole in the top, and the use of modern phillips head screws. They used two 1/2" hex head wood screws per to attach to the roof and no nails. We have a copy of the original blue prints, But remember that the original 18 inch was replaced for 24 inch. The original specifications called for 8 nails in each brace. The brace we found had 8 nail holes, 6 of them toe nailed. So that is what we decided to go for, believing that it’s our best guess. The new safety codes in '03 allowed the braces to be painted, but the top side of the roof walk boards had to remain unpainted, to improve foot traction in inclement weather.
Time to make some saw dust… Have bandsaw, will cut for train rides!
