No work today because my car died and was towed to the shop. Unfortunately no progress on the layout either as I need supplies from Home Depot. So I took out the trash, moved some power tools around and took these pictures. When Marilyn gets home from work I can use her car to make a supplies run.
Here’s that tricky angle section. The vertical is temporary just to hold things up while I fasten sections together…
Looking to the South. I realized I will quickly build myself out of any room for saws…
And back toward the existing bench from the other end…
I figured out that the metal shelving (sections at left of photo above) will fit perfectly inside the new bench and can be used as legs too (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-money-mouth.gif)
And finally, from the ‘finished’ area looking at the opening left from removal of that large built-in liquor cabinet…
Guess all I can do is fiddle with the track plan. I should inventory my switches and only design what I can build with track on hand.
