Ken Brunt said:
Daktah John said:
I don’t plan on building nearly as fast as you did once you decided to go. I’m thinking that I might get the switch cut in and one bench section built in the spring. Then I will have a better idea of cost and time required to build further.
I didn’t plan on getting that much done myself, but once I got started things just fell into place. And the nice weather helped. I just looked at it as a challenge. I also put a limit on how much I would spend each month on material which helped the budget. And reused a lot from the old layout.
It was the pink hat. Dont worry Jon Ill get the hat to you before Spring.
