Over the weekend I refined my site survey to get not only grades, but an accurate location of the tree and correct size of the available space. My previously posted track plans exaggerated the existing space and mis-located the tree I plan to swing around. With survey data in-hand I corrected my RR Track plan. Unfortunately, the available space reduces ability to have a sweeping curve before the reverse loop. This track plan is still very preliminary, but now that I have an accurate survey I can experiment with track plans and know that if I decide that I like one that it will fit in the available space.
First, some more photos. Here a template of an Aristo “Wide” switch is placed where I plan to break away from the main. This exit point is prior to the steep grade climbing the walkway and retaining wall toward Coal Dump Curve…
Closer to track level it’s easy to see the angle and distance to the tree. The string line is dead level and leaves the main at exactly 55 degrees. The tree is 25 feet away…
This wide shot shows the entire area available for development…
And finally, this shot from my living room window give an overview of the area from the other side of the tracks…
Once I had all of the correct data plugged in to RR-Track I modified the previous track plan to fit the space. Again, this is a very preliminary plan. The grid size is 48 inches…
Note that the half circle on the house side of the tree would not exist, I just couldn’t figure out how to hide it in RR-Track.
