I’ve long been a fan of raised outdoor railroads, initially admiring Richard Smith’s system up in Oregon and most recently Ken Brunt’s re-build in Pennsylvania. My railroad was designed to expand North across the front of my house to an un-improved area on the North side of my house. To get to the North Slope (for those who have been following me for a long time) I need to go through the cement and stone front steps to the house. That obstacle kept my expansion plans cool. More recently I’ve given thought to turning West and running out into my back yard on raised bench since the existing track at “Wall” is already 3 feet above the grade of the back yard.
Today I got serious about planning this. Step one was to survey Coal Dump Curve so I could plug it into Visio CAD software and RR Track to play with design ideas. Since Coal Dump Curve was bent to eye, I decided the best way to determine the radius was to lay out a string grid so I could take some measurements. I ran a string diagonally across the inside of the curve from start to finish…
Then ran out the tangents from either end of the curve to the point where they meet at a 90 degree angle…
Then ran a string from the center of the first line to the intersecting point of the tangent lines…
Once this was done, measurements were taken along the string lines to allow me to draw the existing arc in CAD to determine the radius and/or diameter of the curve.
While I was out there, I took my paper template of a USA or Aristo #6 switch and laid it on the track. It looks like the #6 will cut right in to the existing curve which works out to be 16.6 foot diameter or just slightly bigger than Aristo’s 16.5 Ft curves…
Only trouble is, the tangent track will require re-location of a rock that I use often in photos…
This first shot of the expansion real estate illustrates how quickly the ground falls away to the right of the existing track. The track is about 3 foot above grade at the wall…
As we pan to the right (West) where the block retaining wall ends, the ground is nearly 5 feet below track level…
I’d like to build the benchwork nearly dead level, but I want to be able to reach the track as well, so either I build the ground up or change the plan. This long shot shows the tree line at the rear property line. That’s about 60 feet from the existing track…
My original plan was to stay along the lot line, where the block wall and shrub line is, but the grade is a big obstacle. I could turn North again before the grade gets too far out of reach. I do plan on putting a reverse loop in this expansion section to allow loop-to-loop continuous running for my steamer.
The survey fills in the “Givens”, here are a couple of “Druthers” that I’ve worked out:
Benchwork accessible from only one side shall be no higher than 40" from grade and no deeper than 30" to allow me to reach everywhere standing on the ground.
Benchwork accessible from both sides shall be no higher than 40" from grade and no deeper than 50" to allow me to reach everywhere standing on the ground.
Single track elevated roadbed shall be no higher than 50" from grade to allow me to see and reach standing on the ground.
I’m sure I’ll come up with more design criteria before I put saw to material next spring and I’m certainly open to suggestions from those who have gone before me.
Here is a very preliminary track plan - the view is toward the South lot line, existing railroad curves to the left, expansion curves to the right. The curve after the switch is the same 16.5’ Diameter as the existing main line and the reverse loop is 10’ diameter with a “Wide” radius switch. The grid is 48 inches…
Lot’s to think about while the snow flies ![]()
X
