Shane Stewart said:
Boy, somebody seems to be leaving us “toy” guys behind and moving on to museum displays. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
Shane
Nope
Shane
Nope
I’d say “Museum Quality” is a nice compliment.
Rooster - Can you mention the name of the Museum?
Pete Lassen said:
The lack of humidity in a museum would pull all the moisture out of the wood, making it do all sorts of non wood like bends and twists
Pete,
That is my exact conclusion. What I didn’t mention was the type of wood or the length of the runs I had issues with.
Rooster ’ said:
Mick Benton said:
Mick,
That pic taken about 1910 shows where the model I’m working on will reside in the structure behind the car. http://www.mechanicsburgmuseum.org/
Once again the model is for educational purposes only and NOT finished nor prototypically correct or to scale. Only trying to capture the flavor and “HOPEFULLY” peak interest within the generation behind me. I was blessed with A LOT of information over the years from many now deceased elders that knew I had a historical fetish with a “gift” to work with my hands. They shared with me so now I’m passing it on along with other things. (Make sense?)
This stuff needs to be passed on or it will be lost! So if a model as opposed to a picture helps with passing it on then I have won! There are a LOT of things I cannot answer (headlight configuration (note the bracket on the roof where it was moved to the railing) , losing two out of the 4 catenary poles,etc) and I’m sure it didn’t have a brass railing either but I’m doing it because I can and learning skills along the way. BTW the "plow,cowcatcher " is on the model.
I’m rambling but enjoying sharing. When the 5th generations from now dust off the memory chips saved from LSC (and figure out how to make them work like a 45 record) I hope they can carry on the historical end as it’s bottomless!
Thanks Mick !
Composite ties with…never mind…
Did I show these ?
I don’t think so. Awesome job Roo!! That bottom one looks like a catalog shot from a high-end manufacturer (https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-cool.gif)
It’s only a Bachmann Jackson Sharpe car. But as you know they make a very nice base for modifications . That one resides here along with the other.
I think I can fix this thread if anyone is interested. Since we are fixing threads as the current trend.
Following the “10’ rule” with proper gauge/scale while checking back to back spacing!
Yes. If you are willing to put in the effort, I think you should.
I’ve found for posts with multiple pictures to repair, you can copy all the text from the editor into a word processor, then use search and replace all to fix what’s broken.
Or, you can simply drag in the pictures from your source if you know what is what.
Ok …fixed as best as I can. Guess I need to add a pic of it at the museum which I don’t have.
Thank you Jerry, he used to beat me regularly back in the day !
And NOW he just beats you irregularly?
For a thread resurrection lasting more than 4 hours please seek …ahhh never mind
[quote=“Ken_Brunt, post:6, topic:78537, full:true”]
And I’m guessin you’ll try and sneak that into Delores Yard, too, while we’re eating lunch for a photo op…
Fat chance!..
I might now that you can’t stop me!
You old goat I miss ya’ already and I don’t know why !
Dang, I’m on top of the game as it appears I already semi fixed this thread as well !
you have earned the right to let go a joyfull crow!
