Bill, link to files sent via email. Let me know if you do not receive it.
Thanks Dan!
Hope to get on to it this week.
Looking good, Bill. Let me know if you have any issues figuring out how it all goes together. I just mounted mine on a piece of 20mm plywood. You’ll have to play with the roller adjustments to get the results you want. You can also print rollers with different profiles. I use 0.003" steel shim stock. I do not anneal it, but it would probably give better results if I did.
Thanks Dan,
I’m really looking forward to building this beast. I haven’t found the hardware list you mentioned would be in a second email.
What size nuts and bolts do I need to look for?
