Need some technical help Guys.
Here is what I did. I went to Home Depot and got a roll of Aluminum flashing 8” x 50’ for $18.00. It’s .0092 thick. There is no ID on the package that tells me what Alloy it is.
Downloaded that data sheet that Bob suggested and read the data on the alloys. The Annealing temp. from all the Alloys ranged from 630- 780 degrees. I figured that the top temp would cover most everything.
Here’s the stuff: I used my 8” sheer to cut the roll to 12” lengths, and also made a few to 1.375” x8” as that is the size to run thru the dies.
Cut some small pieces for interleaving the stack and folded for Airspace.
Loaded the Kiln with the sheets, and tossed in 5 soda cans cut open.
Set the kiln to ramp up at 1000 deg. per hr. to go to a temp of 780 deg. and hold for 1 hr. and then free cool to 250 deg.
When cool this is what I ended up with.
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/Roof%20rolling%20Machine/Roofroller-43_zps407de869.jpg)
There is some kind of coating on the flashing. One side turned Black and the other Gold brown. The soda cans burnt.
My observations.
The soda cans definitely annealed. there is an very definite different feel to the cans and they kink easily and stay that way.
I’m not so sure that the flashing annealed. It has a bit of different feel to it, but it still feels “stiff”, not soft like I would expect.
I washed off the burnt coating easily in warm water. I ran sone test pieces thru the dies. The soda cans are differently softer, but they are 1/2 the thickness. They did not tear like the un-annealed ones did.
The flashing was “softer” then the original, but did act alot like the un-annealed.
OK. what did I do wrong on the Annealing? Will heating it to hot, be a problem? It did Sag in the kiln, and now the sag is kinda set in. Cooled to fast? Added a slight temper back in?
