Last summer some tomato plants volunteered to grow in about 10 cu ft of dirt that sat through the previous winter in my garden tractor trailer. Marilyn wouldn’t let me pull them up and added a few other vegetables. It was fun for her because it was up off the ground at an easy height to work.
This year I want my trailer and my dirt back so we picked up 15 cu. ft. of garden soil on sale at Home Depot for $2/cu ft. I have the remnants of a heavy duty platform Matthew built 5 years ago as part of a snowboard ramp that will supply all the needed posts and lumber.
The plan is for a 4’ x 3’ x 18" deep box with the top edge at about 33" above grade. Since I’m not using pressure treated plywood I only expect to get 3 years out of it before it begins to crumble, but the price of $0 is definitely right. I may line the walls with 3mm PVC to help slow the rot. The dirt will sit a few inches above the plywood bottom supported by weed block fabric over hardware cloth supported on PVC boards about an inch and a half above the plywood base. The base will have drain / air circulation holes. Under the plywood base will be a 2x6 wood frame for support. All of this will be supported on 4x4 posts.
Demolition of the existing base was completed tonight. Looks like rain tomorrow so construction might begin Wednesday. I’ll post some pics whan I have something to show other than a pile of reclaimed wood.
