Todd Brody said:
It’s just too damn expensive to operate for what it does and goes though disks too quickly whereas you inferred that its perfect for every situation and if it is not, it must be that the person using it has it adjusted incorrectly.
Todd
We seem to have morphed the rail to wheel contact being the weakest link thread to Brass Track cleaning. For this reason I spun this separate topic off to a new thread.
On the SJR&P we are slowly replacing all our brass track with SS track. Yes the cleaning problems are much less but the other reason is deer which mess up brass track but have no effect on SS track.
We still have a couple hundred feet of brass track left (less after the track work we are now doing) and yes we still clean it before every operating session.
As I said before we outlawed the LGB track cleaning locomotive, it cleans the track but leaves residue which is picked up by the locomotive wheels. And as you point out is expensive to operate and it is important that you run it at between 22 and 24 volts for proper operation.
Instead of using the LGB locomotive we purchased a pole sander and use #600 wet dry paper to clean the brass track. We wet the rail with a hose use the pole sander to clean and then wash it off. Sounds complicated but is actually rather fast and the rails are really clean after that. One sheet produces two sheets for the pole sander and one pole sander sheet is sufficient to clean all the brass track we have left. If you purchase 25 or 50 sheets in a bulk pack it is not expensive to use.
One other off topic comment. Looking at the photo of your track shows ties which the UV has almost destroyed. Suggest you put some UV protective paint on it shortly to extend their life.
Stan
