Molding is all done, no particular surprises. Somewhere around 25 – 30 layers on these all up.
We’ve moved into summer proper now, temps in the 70’s and 80’s most days so I was getting 3 coats done in an evening, and up to 8 on a weekend day. Two weeks work to get to this stage…
Since latex is no good for filling in undercuts, even using thickener, thought I’d get clever and try using urethane rubber (proper name) – Smooth On 40 as a fill layer where I needed it. Claims to stick to vertical surfaces and mostly lived up to what the label said.
I did the big undercuts in several coats and got what seems to be a good result… Longer term is – experimental. Different expansion & shrinkage rates might cause separation of the layers but I tried to do a pretty good sandwich between two layers of latex.
The price of this stuff in NZ is eye watering. If I had a choice I’d do the whole mold in Rebound and smash it out in 1 day, but this would have tipped the cost to over $1000 – just in rubber. Never mind that it’s Out of Stock in the whole country. The Latex cost me $150 for 8 litres (2-ish gals). Big disadvantage is the number of coats, and the time it takes.
I’m leaving this lot for a week to fully cure before adding the glass layer.
I’ve think I’ve done enough research on GRC to know that it’s possible to do what I want, but finding the materials in New Zealand has been – expensive (again). Many online clicks later and I now have the two hard to get ingredients: 10 kg Alkali Resistant Glass Fibre & GRC Acrylic Polymer.
Cheers
Neil
