Well … it had to happen sooner or later. I’ve been planning this car barn for the past six years but never got around to actually working on it. I poured the concrete slab back in January 2011 at the same time that I poured the slab for my work shop building. Here is what it looked like back then. That’s the forms for the shop foundation in the background.
After I poured the slab, it just sat there – collecting various materials as I worked on the rest of the layout. Here is the slab in the background back in June of 2012 after the shop building was completed. One of my granddaughters was running a sheep extra on the newly laid portion of the RGS outer loop. You can see the slab above the loco and the first sheep car.
And now, I feel really bad after seeing some of the photos of the car barns that some of you guys have already built. So – bottom line – you shamed me into finally starting the thing. Thanks.
Here is the 2 x 4 framing I put in yesterday. It is pressure treated yellow pine.
Today I started on the roof assembly. I am framing it with aluminum angle and PVC lumber to keep the weight down. The roof will be polycarbonate panels. I will hinge the roof assembly along one of the long walls and use a 12 volt linear actuator to open and close the roof by remote control. I’m not sure yet what I will use for sheathing the stud walls, but I’m leaning toward T 1-11 plywood siding with a 4" board spacing. I’m open to alternative suggestions.
More photos to follow as work progresses,
Bob
