Rodney, Fred and all are doing their best to convince me to put proper ties on the bridge I am rehabilitating. This is a extremely low budget project, so if it can’t be made with materials on-hand it’s not getting done. What I have on hand is small pieces of PVC board. I did my due diligence and researched several prototype bridges. Most of the bridges I examined appeared to have the following specs: Bridge Ties: 8" x 8" - Length varies by gauge and inclusion of walkways Tie spacing: 3" to 6" Guard Timbers: 4" x 8" So how do standard PVC sizes compare? Falling back once again to 1:20.32 being the same as 15mm per foot (45mm track = 3 foot gauge), I come up with the following… 3mm PVC Board is about 2.5 scale inches thick (Actual 2.4") 6mm PVC Board is about 5 scale inches thick (Actual 4.8") 12mm PVC Board is about 9.5 scale inches thick (Actual 9.6") I think this are close enough to be usable… 9.5" x 9.5" x 8’ Bridge Ties - 5" x 9.5" Bridge Timbers in 8’ and 16’ lengths
I cut up a a whole bunch of the above shapes so I could lay out a test section and experiment with assembly methods. PVC sure does make a mess when you rip cut it
Could use the sawdust for scale snow if I kept it clean. Somewhat like a Jenga puzzle, I laid out a 24 scale foot section. I used both 3mm (2.5") and 6mm (5") spacing to compare the look…
I think I like the 6mm spacing at left best. The over-size ties look a little better spaced a bit further apart. This is going to look a little clunky with my 1:29 and 1:24 stuff, but should look OK with 7/8’s if I ever go there. SO… If I can figure out how to build this into a long section, color it and spike rail to it - will it pass muster? Do you prefer the close or wide spacing ? I’m not planning on guard rails. Several of the prototypes that I looked at don’t have them, and because this is a lift-out they would add more complexity to that function.
