When I put in Buchanan Tool & Die, (http://www.largescalecentral.com/LSCForums/viewtopic.php?id=13987) I had hoped to just move Miracle Chair Company to a new location.
However, that didn’t work out as it was rotted beyond repair (http://www.largescalecentral.com/LSCForums/viewtopic.php?id=14179) It was time to start a new building. Mike Oates lives quite close and has been a frequent attendee at my operating sessions, so I decided it was time to name a building in his honor. I was able to salvage most of the windows as well as the loading dock and some other pieces.
I built a quick mock up using some old foam board.
Even though I salvaged a bunch of windows from the old building, it became clear that I would need many more. I started to build some using my jigs.
The brown one is a Grandt Line window from Miracle Chair. It was originally maroon. The white ones are the ones I made from styrene strips. I’m using 1/4" Sintra (Kemotex PVC Board) for the walls. This is one of the sides after I laid out the windows.
The Sintra cuts with a knife, though it takes a number of passes. After I get a nice groove, I found it easier to use a razor saw to cut out the opening.
The windows look good, though there will be some clapboard siding on the finished side.
After the windows are cut, it’s time to glue the walls together.
The clamps help to hold everything in place while the glue dries. I use Weld-On 16.
I had originally thought that I would NOT do a front, as it will not be seen, but I figured that I might move it someday and the front would be visible.
I’ll put a sign in the middle part. I do have a problem. The front is over 20" wide, but the siding is only 15". Thus, I will have a seam. That’s not an issue on the other sides - the left side is just 14.5". I would have liked some feature on the front, such as a vestibule, but I really couldn’t come up with something that looked good. I’ll have to see if I can disguise the seam…
I started with some .060" styrene. Made a pattern and then used it to create the other sides.
