Got the pilot deck painted and installed. Also added the air hose.
Cut the running boards for the fireman’s side and installed them.
If you don’t operate at night you might as well leave the headlight off as well
Gary Buchanan said:Operate is the key word.
If you don't operate at night you might as well leave the headlight off as well ;)
I use the lights to indicate direction! Very handy when switching…
So I found out
This has to be some kind of record for Chandler. 33 pages, nearly 500 replies and over 25,000 views. Amazing!
Keep it up! LOL
Randy
Randy McDonald said:It just shows how slow I'm going. ;)
This has to be some kind of record for Chandler. 33 pages, nearly 500 replies and over 25,000 views. Amazing! Keep it up! LOL Randy
But amazing modelling!!!
Randy
Amazing indeed.
Bruce,
What color/kind of paint did you use on the smokebox?
Ralph,
It’s Testors Graphite Dust. http://www.hobbylinc.com/htm/tes/tes1849m.htm
When sprayed on, it was way too shiny, so I sprayed some Behlen Dead Flat (http://woodworker.com/dead-flat-spray-finish-mssu-934-154.asp?search=dead%20flat&searchmode=2) on to it…really changed the look.
It’s still not as dark as I want it to be.
Thanks Bruce.
I see it is a lacquer. I bet it did shine.
I like it.
Added the grate shakers to the floor of the backhead. Also fashioned the step for the fireman to open the doors.
Looking good Bruce. Mind expanding on grate shakers, are they the six rods coming up from the floor?
David,
That’s correct. 3 on each side. I cheated…they don’t go through the floor. The step for the firebox door doesn’t work either.
Slacking off near the end. How you going to keep the fires burning if the grates don’t move? You did build the grates,right?
Amazing work!
David Marconi said:I'm just trying to extend the topic. ;)
Slacking off near the end. How you going to keep the fires burning if the grates don't move? You did build the grates,right? :) ;)
No grates.
I did put some piping in the cab, but you can only see it if the cab is off.
Oh well. On to the air pumps!
Bruce Chandler said:David Marconi said:I'm just trying to extend the topic. ;)
Slacking off near the end. How you going to keep the fires burning if the grates don't move? You did build the grates,right? :) ;)No grates.
No plow. We don’t get enough snow here to justify a plow.
