" Rooster " said:
Andy Clarke said:
Yeah, Jon… was the second one I wanted, along with 5 others I was going to post…
Dad are these the ones ?
Son, yes those are and thank you for posting them…
Below is a shot of the north west wall with the switches to the different locations… First right hand switch at the bottom is the main line…
The second right hand switch goes into the freight yard and the track at the back along the door runs to the industrial area.
The below shot shows the Main line in the foreground along with the start of a siding… The next six tracks is the Freight yard tracks…
In the background, you can see some of the tracks of the industrial area…
Below shot shows the Main line and siding in the foreground… The NW-2 is sitting in an engine pocket track… The tracks with the trains on them is a temporary freight yard for the outside operations…
There is an incline track that allows trains to be run from the lower level to the upper level, so cars don’t need to be picked up and moved…
Below is a shot from one aisle showing the mainline on the left and the siding… The GP-38 is sitting in another engine pocket track… The right side shows the leads into the freight yard.
The below picture shows the same location but from the aisle between the freight yard and the industrial area.
I appreciate all the help in getting the pictures to show… Thank you…
