This build has been awhile in the making. First was the wall scribed from sheet stock
Next I cut the forms for the bay windows
The windows for the bays had to be made
The forms needed scribed siding
Trim layers cut and fit
Checked for fit and overhangs added
Then I decided to add a third floor section with dormers
More window trim and some color added
Testing the bay colors
Work on the adjacent roof trim
Third floor with paint
I’m working on the second floor windows at the other end of the block, and a third roof trim area. This will be a four sided structure and not just false fronts, but it will take awhile scribing the brick and block work. Wood siding will also be scribed and used to the rear of the buildings. Updates will be slow but they will be done. Projected completion date is in the future.
