Again nice weather, day was used taking our “peanut” to the vets for a check up and setting up a time t have his teeth cleaned and some growths removed, not a happy boy, was able to get the termite shields done and secured to the concrete pillars got them to fold over toward the pillars using a heat gun on low, found that there is a side that folds up and the other down with heat. After gluing the shields to the pillars I sprayed right up using silver rattle can and after drying sprayed upside down with grey primer on the pillars, actually came out better than I expected. Also ground down a chimney section that fits in the playmobil roof center line that will accept the MIK chimney that way if running behind I will still be able to finish the project if I don’t get to the outside one, more to come, Bill
