Hi all, Oh, what clamour from the side lines!? And how to stem the tide?!
There seems to be some doubt, in certain quarters, as to my ability to produce a nice RhB item from a LGB product. Well, to keep the āchorusā at bay, I will document the āstep by stepā procedure of converting a Ballenberg Postal-Baggage to a RhB D4006-4024 series Baggage. In 2m aka LargeScale @ 1:22.5 I restrict myself to building items which will be used on our layout - not the āEPLā, but the RhB Grischun - and of course Iām always looking at ways to kitbash items that have similar, if not identical, properties into proper RhB rolling stock. The Ballenberg Postal-Baggage is an excellent start to at least two RhB cars, one of them being the D4016. Thatās the number I chose because it was still running in its original livery and assigned to its accustomed duty for the era in question.
Thatās what the car looked like shortly after arrival. BTW it was a US$100 bargain during the big LGB flog at RRS! Donāt worry about the relatively clean workbench, itās my quirky Swiss upbringing.
But on with the bashing; the P-B is longer than required for the D4016 and as luck has it removing the two panels - left and right - in which the windows are located will give the correct length. This could either be done on the table saw or in this case I decided on doing it in the milling machine, since the car body fits in the vise and the resulting cuts will need minimal clean-up. Of course if one desires one can also do the cuts with a razor saw, clean-up with a file and so on⦠I did mention that Iām lazy, didnāt I? Anything that can be the done the easy way, will be done the easy way. Wearing a hairshirt has never been my choice! So anyway, to stabilize the flopping walls I cut wood spacers which are inserted between the walls. More on that later.
