David Maynard said:
You would think that a “standard” decoder should work. But in Large Scale we don’t have the standards the smaller scales have.
I agree, there should be some published information, on Bachmann’s site, as to what decoders will work. That would be nice to know before someone just plugs in a decoder and fries something.
You would expect Large Scale to follow suit? Why?
David
The Bachmann Peter Witt follows the industry approved 21MTC Standard. The 21MTC interface specifications were developed by ESU and are maintained by Railcommunity and published by MOROP which in this case is the authoritative data source. Locomotive that use this interface to the best of my knowledge all follow this standard.
http://www.morop.eu/de/normes/nem660_d.pdf
This standard clearly states that AUX 3-5 pins are logic level pins.
The NMRA in translating this standard to English apparently made a mistake that was not noticed until recently. Once notified of this mistake they properly notated the problem. They will fix the mistake in their next release.
In my opinion a decoder should not refer itself as a MTC21 decoder unless it follows this industry standard.
Unfortunately Zimo produced two versions, one that follows the standard and one that does not.
This is likely why they note on their WWW site the following.
“WARNING: in any cases a “C-type” should be used instead of a “D-type”, because Logic level outputs for FA3, FA4 are needed, especially locos from: Märklin, Trix, LS models, …:”
Please note that the Peter Witt is a LS model.
If you plug a Zimo D version decoder into any locomotive (in any scale) that has a industry standard MTC21 interface that use AUX-3-5 it is not going to work properly. Note the Bachmann Peter Witt uses a logic level AUX3 as specified in the standard.
I view this as a ZIMO and not a Bachmann problem. However now that Bachmann is aware of the problem I agree they should provide a warning to follow the ZIMO instructions and not to use the ZIMO D version decoders.
One other note. The current approved standard allows for different impedance speakers which must be clearly documented. Older MTC21 decoders and locomotives use 100 ohm speakers. Newer ones use 8 ohm speakers. The Bachmann Peter Witt uses an 8 ohm speaker. If you use a decoder that requires a 100 Ohm speaker it is not going to work. (again same warning in all scales). I believe the next update of the MOROP standard will move to 8 ohm as the standard as well.
Greg used a decoder that does not follow the industry approved 21MTC standard and whose manufacturer recommends not to use for this purpose. I am not surprised at all that it does not work.
Bottom line, before installing a decoder read the documentation to ensure it is the proper decoder for the locomotive you intend to install it in…
Stan
