Bob Cope said:
Ken,
Thanks for the great photos. The small board in the bottom photo below the brass flywheel is the culprit. I see you are still using yours
I also appreciate the up close and personal photo of Rodney’s gearbox installed. For some reason I could not get that picture in my head before. His regear is on my agenda of upgrades to do while this loco is in the backshop. Along with battery and R/C (to be wired to a switch so she can be run on track power as well).
Is that additional weight you added in front of the stock weights? If so, how much did you add? Last question, do you have any issues with the pilot truck tracking? I am looking at trying to put a slightly heavier spring in the pilot assembly to possibly make it track better, along with additional weight in the boiler.
Thanks for the response, and sorry for the additional questions.
Bob C.
No, all that weight came with it. However, I did remove the weights that were in the tender. Necessary to fit all the battery and R/C stuff that was installed. If thats the route your taking, you could use that for additional weight, but I doubt if you’ll need it. That sucker weighs a ton as it is.
The R/C and Sound were all plug-n-play, so taking out the circuit boards was more trouble then it was worth.
I sometimes have an issue with the pilot truck, but that could be with related to problems with the track itself that occur occasionally, it hasn’t been an on going issue, yet. A heavier spring probably wouldn’t hurt.
The gearbox install will require you to remove the fan and reposition the circuit board next to it, simple really. I cut the screw tabs shorter and moved it up a bit.
Tony, the smoke unit is one of the first things removed. For the pitiful amount of smoke it produces, I can’t see wasting the electrons on it. The electrons find a better use by moving the goods to customers…
No problem with the questions, just glad to help.
