Nicolas Teeuwen said:
Purchased an Aristocraft #6 switch and tried it out with powered track. I expected it to work like all other track I have worked with in the past (N-Scale, HO and Lego) in which the power only goes to the side that the switch is directing too. I did not expect both sides of this switch to be powered.
Is this normal?
Do USA Trains #6 switches do this as well?
How does one set this up to park an engine on a siding if its receiving power as well? I would imagine insulators and a separate run of power to that section that would possibly be on a different power pack?
The #6 has a micro switch that powers the frog with the correct polarity. Post the frog there are jumper wires that keep both legs powered. You can see these connections if you look on the underside of the turnout.
To have a section of track that is only powered if the turnout is set you would need to do two things.
remove the jumper to the leg of the turnout that goes to the siding you which to power down.
jumper this section of track to the wire that goes to the frog. The siding will not only be powered when the turnout is set.
Note that the micro switch is not the best for multi amps of power. It will work but having the microswitch power a 10 amp relay is a better solution.
Hope that helps
Stan
