For the record, The news stories you’r hearing about the Animas River mine pollution is RR related. The plume has migrated down stream thru Durango Co. and has made it to Farmington. Having several days notice of it making it here, all the taps from the river have shut down, and the local drinking water systems are all OK. The irrigation ditches from the river have all shut off there intakes, and no water is being drawn into the systems. The Ditch that runs thru my back yard, and the one that feeds my river thru my pike is non flowing, so I won’t have to do an EPA clean up program on my creek.
That said, The source of the pollution is the “Gold King Mine” located at the top of Cement Creek, North of Silverton. The Gold King was one of the larger mines in the Silverton area and was the reason that the Silverton, Gladstone & Northerly RR was built. It was one of the 3 small RRs that ran out of Silverton. It was later merged into the Silverton Northern RR. Long since closed, the mine had been “Leaking” mine water from the tunnels. The EPA in an attempt to stem the flow “Plugged” the portal a couple years ago. They were caught by surprise as to the amount of water behind the plug, and while trying to “Tap” the plug, caused it to fail, with the release of 1million+ gallons of old mine water. OOPS! The exact content of heavy metals, and the amount in the water has not been released yet.
NOTE: NO POLITICAL COMMENTS ALLOWED ABOUT THE EPA on this thread!!! Train yes, Colorado NG RRing Yes, EPA NO! Silverton and RRing yes, D&S yes.
