I believe it was Bob that coined the term “operations-quality”. It’s not a contest quality model at all, but is designed to hold up to the rigors of being transported between shed and railroad without losing a lot of pieces along the way.
I had some wood siding and other parts lying around so decided to make such a car. It should be pretty sturdy; it uses some superglue and brass escutcheon pins to hold parts in place.
The stirrup steps are made from brass strips I had; I followed the article here to build them. the grab irons are also brass - 1 mm rod in this case and formed using a jig.
The door hardware is all brass; not much detail, but enough to look like a door if you squint from 10 feet away…
There’s no brake detail, although there is a cylinder glued underneath; the idea is to not add details that are not seen in a typical operations session.
The roof walk strips will be glued in place after it receives a coat of paint.
Trucks are from AMS.
Nothing fancy, but hopefully a good operating car.
